I’ve been testing out the kicad_freerouting-plugin and found my self constantly clearing the tracks, re-filling the ground fills then running the auto route as I adjusted placing things.
Whilst this isn’t hard it’s 4 clicks and a key press.
Alternatively one could use the selection filter to only select tracks, then press control+a and delete on the keyboard. I think there might also be a way of assigning a keyboard shortcut to a selection profile to speed this process up.
edit > global deletions > tracks & vias, OK, then confirm; that’s the four clicks and a keypress (or five clicks).
Two clicks (uncheck All items, check Tracks) and two keypresses. A third click if you want to delete vias too. (Which apparently the plugin does not do.) And afterwards another click to restore the selection filter to all items.
I do, lots of times. For instance, hand routing and I decide I want to redo some area of the board, not the whole thing: Uncheck All items, check tracks and vias, drag select the region, hit delete, tracks are gone in that area.
are there any good you tube vids on using Kicad ? a complete beginner here . I have a couple simple things I would like to do , so I can have pcb’s made .
I started with this series, I can imagine better but it was good enough. Started watching one evening and by about 3 am I was submitting an order for a (stupid simple tiny) PCB. But it’s for KiCad version 5 and we’re now on version 6, so that might be an issue.
