So I’m breadboarding a MFOS WSG, but am unsure what to do about the bypass caps in the schematic. C9 and C10 are shown as 0.1µF and after reading various posts on here, watching an Aussie bloke on YouTube and reading various linked to blogs, I understand what they’re for. What I don’t understand is where they go. The original schematic has two chips, a CD40106 and a LM741, do I put both caps on one chip, both chips, or just between the +9v and GND rails…?
Best practice is one bypass cap per power pin per chip, placed close to that pin. So two bypass caps for op amps with ±12 V supply. Here I guess there’s one LM741 and one CD40106, each with one +9 V pin, so one cap near each of those.
I was thinking about this a bit more. What’s confusing me isn’t the MFOS schematics, but David Haillant’s one. If he’s running the final op amp off +/112v then shirley there needs to be four bypass caps, rather than three…? One on the CD40106, one on the first LM741 and two (one for +ve, one for -ve) on the last LM741…? C11 in his schematic seems to be a 220µF electrolytic, rather than a small ceramic, which I don’t understand.
Here’s what I think’s happening: It’s confusingly laid out, but C9 and C10 are bypass caps for the +9 V powered chips, and C101 and C102 are bypass caps for U102. If you look in the interactive BOM there’s a PCB layout which supports this. And C11 is … an overly large (HUGELY large) output cap for the +9 V regulator? It does sit next to the regulator on the PCB. And there’s no electrolytic bypass caps on the ±12 V rails? That astonishes me. Almost any other designer would have put something like 10 µF from rails to ground near the power header, and I would probably have put no output capacitor at all on the 78L09, definitely not one anywhere near as large as 220 µF.
Ah, right, I see. Not sure why that’s there… unless it’s to deliberately make it make strange noises when powered off as alluded to in the comment. Certainly I see no reason for it to be there in the Eurorack version.
And I’m really perplexed by the lack of electrolytic bypass caps. Haillant has them on all their other modules, it looks like.
Do small ceramics on the power pins actually matter that much for analogue audio? They’re mostly effective far above the audio band, I thought. Pretty crucial when you have a lot of digital switching kicking all sorts of high frequency noise into the power supply.
Probably don’t matter that much. Sam is known to leave them out a lot, and I’ve left them out temporarily when I’ve run out of them and not noticed any ill effects.
On the other hand, they cost like a penny a piece, take up almost no real estate, and have no bad effects I know of, so I use them.
I didn’t have then in until a couple of days ago, and there was no noticeable difference. I’m running off a 9v PSU though, so maybe running off a 9v battery like the WSG was designed to do, they would make more of a difference when the battery starts to go…
