Identify Mystery Board - Solid State Music 10-3 circa 1976
Any idea what this may have been intended for? It’s gorgeous.
EDIT: I guess I’ll answer that myself. Isn’t it neat how you manage to find the answer yourself right after you ask?
http://www.s100computers.com/Hardware%20Folder/SSM/History/History.htm
Apparently it’s a static ram card for an S100 bus computer:
Solid State Music or SSM as they were often called, were known as the “Blue S-100 boards” company. Their boards were blue colored and while a few other S-100 board manufactures from time to time used boards of this colored material, SSM really made a point of using that material.
SSM was/is well known in the electronic music community for their voltage-controlled oscillators, filters, amplifiers, envelope generators, and so on, all of which were implemented on chips (previously synth circuits were discrete-component designs). The rise of SSM coincided with the first uses of microprocessors in synthesizer keyboards and other music gear like drum machines; early computer-controlled analog synthesizers like the Sequential Circuits Prophet 5, for example (which, I believe, used a Z80 processor), utilized SSM chips for the actual sound production. (The Kawai K3 synth from 1985 has SSM chips in it as well.) SSM chips are still used in some new synth eqipment, like some of Doepfer’s line of synthesizer modules which are marketed specifically for the distinctive “SSM sound”.
The company was located in Santa Clara initially and later San Jose , CA. They started in the S-100 bus business like most by supplying static RAM cards, but their claim to fame was their early video display card, their VB1A. It was a very reliable and popular video display card in the early days of the S-100 bus. Many early memory mapped video games were run from either this card or the Processor Technology VDM-1. Another great thing about SSM Boards was they wrote great construction manuals. Also they went into the theory of the board often with signal profiles.
There is some mention on the web of a “Solid State Music System Sound Synthesizer Card” where five SB-1 synthesizer cards plugged into an S-100 microcomputer with 32K RAM. Each card provides one channel of music, with control over the envelope and waveform shape, volume, and pitch of the note played over an 8-octave range. Music for the SB-1 is written in MUS-X1, which allows high-level control of the SB-1’s special features and simplified encoding of the music. The MUS-X1 interpreter was also able to play “inverted” music from a normally encoded song. Unfortunately that is all the information I have.
looks like you could hang it up as art .
“Solid State Music System Sound Synthesizer Card” watch out you will get Sam on another project
[ furby,gameboy , etc.]
I was going to guess it was an aftermarket memory card for the Buchla 208. Glad you found the answer before I made a fool of myself. Oh wait…
Fascinating. I thought it might be a S100 card given the date, but those are supposed to have had 100 fingers, whereas the Anchor Electronics website describes this board as having only 80 fingers.
https://anchor-electronics.com/product/mystery-boardsolid-state-music-10-3circa-1976/
I counted, there are 50 on each side, so the description is wrong. I just ordered one along with more knobs and things. I have a vague plan to frame and hang it. $4.95 is my kind of price for art :heart_eyes:
I did that with some old magnetic core memory, apparently from an early Soviet computer. It’s a bit geeky, but it’s cool! I used anti reflective glass, it improves the contrast of stuff under it.
That’s the coolest high-lo tech found art I’ve ever seen.
Lookie what I have sitting in an old computer electronics box in my shop.
In my case, these are sound cards for the Imsai 8080, the computer famous from the movie War Games. I inherited this stuff from a family member, an overwhelming amount.
There is more about it or a version of it here:
OMG, how random and awesome is that!
That looks fantastic!
not sure what they are [ search didn’t turn up much] some kind of old IC mounted on ceramic. always thought they looked cool .
So they’re American Microsystems chips manufactured 1972, but that’s about as far I got – seems that company did both standard and custom chips, so they can be pretty much anything.
Amazing kit! Thanks for sharing!
A working IMSAI 8080, that’s definitely museum-worthy.
Sorry for the necro bump, but what you have is not S-100 as it only has 80 pins on the connector and not 100. (Count 40 pins on each side… and not 50.)
I can add to the mystery as I have the bus board for it but cannot find anything about it either!
would it be possible to get the MT-2 board from you?
a friend located the processor board, and I’d like to try to put the board set together
i’ve collected what I know at Index of /pdf/solidStateMusic/80pin
the IO-3 has an 8255, ram and two 1702 eproms on it.
Anchor Electronics had one of these backplanes left.
I’m accumulating information for the boards at
http://bitsavers.org/pdf/solidStateMusic/80pin
For sure, if you want, I got it. Haven’t found a use for it and you can have it
