probably worth starting by specifying what features you want, how much money you want to spend etc, if you want a simple VCO this may mean using an IC like the SSI2131 etc, there are simpler circuits to start with, atari punk console etc
Thanks for your reply @amazingsynth.com
I want to build up to building complex modules.
I am seeing the diy journey as a series of stepping stones.
I suppose my $$ budget for my first build is $50 aud or less.
I was thinking very simple VCA, VCO ect to have a basic first diy rig.
If you’ve never made anything before, build Sam’s super simple oscillator, just to get one under your belt. Then make a DIY Low Pass Gate with an A/D envelope generator, or even just a button. Then, you’ll have a machine that makes plucky beeps, and you can build what you think you need from there - probably a 3340 based VCO and any type of filter you like. I like Barton Musical Circuit boards, too.
Hi @BlackDeath
I am coming at this with no previous electronic building experience. I am/was a visual artist in painting and drawing. What i do get confused with is parts and which one is best on the sites i need to buy from.
Ill try what you recommend and move on from there.
Barton Musical Circuit boards look great. Im still learning how to read the plans.
