Hello,
Been snooping the LMNC forums for a long time, and I have learned lots of great DIY stuff here. Using the knowledge gained I’ve built a few cool synth projects too.
Currently, I’m building a “white noise” machine that can sweep between LP and BP filters and want to use the SSI2164 chip as the filter core. The device will run on a dual ±5V supply. I’m borrowing the filter core schematic from MI Ripples/Shruthi & SSI “Designing Voltage Controlled Filters for
Synthesizers with the SSI2164” document.
I haven’t been able to find a version of a 2164 core-based 4-pole LP filter without resonance. For my application resonance isn’t required so I’d like to omit it.
Can I simply remove the OTA or OPamp where the resonance taps into the last filter stage and feeds back to the input? That’s what I’ve done in the linked schematic image and replaced it with a 33kresistor. Also shown is the resonance part of the circuit I removed. I breadboarded this up but so far no dice, just a high-pitched oscillation.
I know the MI Ripples euro rack module will run on ±5v since I can run the one I built using that power source, and MI Shruthi runs on ±5v so I’m ruling that out as a potential issue.
Before I start pulling my hair out over what’s wrong I figured I should probably ask if this filter core schematic would even function as-is. Much of the design has been stripped away.
Thanks!
