Got a good book about programming FPGAs by Simon Monk called ‘Programming FPGAs’. Got the software working on a virtual windows machine as well as my old Windows laptop and built a data selector logic circuit. You can assign inputs and outputs to actual pins on the chip, which is useful!
FPGA is a bog I rarely step in. My personal feeling is that it’s a step too far for me. That said if you manage to get a combo of hardware and code that works then document the hell out of it, back everything up and never change your method again. Do keep us posted.
That said, you could probably follow the directions that use Vivado (Xilinx’s FPGA coding toolset), which would probably be easier to get up and running.
I don’t know where I’d start for DTMF decoding though, sorry…
Good advice, thank you. A friend whom I miss, suggested I get into FPGAs in the early 2000s. Should have done it then, maybe my career would have taken a different route?
Thanks for the links, will look at that. Open source means I can use it on my Mac natively via Brew.
Am running Quartus with a Cyclone IV & Cyclone II chips at the moment. Have got my head around how the development environment works, couldn’t even do that when my stalker was living next door.
I don’t have much of an idea for DTMF either, but things are starting to click into place as I’m learning. Like the massively parallel way things can be done on a FPGA, and the way you can make it all dance to the same clock, or different clock signals!
