I’ll re upload them. If you don’t mind another question: when I upload a new file (fix/update/whatever) does it replace the old file destructively or is there a record kept automatically?
For example for the buffered mult, would probably useful in your case since you have a pcb that matches. But also the corrections need to be done
Yeah, that’s the whole point of Git (upon which GitHub is based): it keeps all versions of all the files and you can go in and recover an old version when you need to.
(That said, today I explicitly created a “V1” folder within my Gate Grinder repository for the schematics and PCB as produced, alongside the corrected and improved versions I’ve made more recently. You could dig those versions out, but I felt like having them there for people to find without having to drill down into the version history.)
I don’t know Git, but normally revision control systems let you tag files for example with release numbers so one can retrieve a set of consistent files corresponding to a given release. That way you don’t need to create folders or zip files together.
Not zipping files together also makes it easier to see the differences between one version of a file and the next.
yeah I am an old carpenter and even when I look at git hub my old eyes glaze over and my pee brain goes WTF am I looking at LOL . I envy you guys that can look at the lines of “code” and it makes perfect sense to you .
