I’m working on a simple power supply using a DKE15A-12. I got a fuse and reverse polarity protection in, but I’m wondering if I need filtering caps on the input and the output.
I did some tests but even a 10uF capacitor didn’t seem to make much difference. (my oscilloscope is very cheap though).
I combed through other similar schematics and they don’t use any caps either.
I used a couple of modules for load and measured around 20mv of output ripple. I’m guessing that 60mv is worst case scenario at full load. I was able to get it down to 10mv with chonky 470uF capacitors, but that doesn’t seem worth it. Going to keep it simple.
Why not? That’s a significant reduction in your noise floor for a couple of dollars worth of components. If vertical space is the issue, it looks like you could bend the legs so that they mount almost horizontally.
