For years I have struggled by with an old Antex standard Iron ( we had them at school and they were better than the Weller so I was brand loyal). Over time I lost, purchased replacement, found, broke, replaced… Etc… So I had 3 Antex and 1 cheap but usable Chinese thing.
They were all OK for intermediate work . So poor for solering on car wires, and poor for intricate work.
Having decided to become more interested in building and repair electronics I had to get something a bit better.
I started looking and almost bought something for £60 that I can’t even remember what it was. I randomly ( I think this was Boxing Day ) found the Yihua 853D , reviews were a mix of Great, Ok and Dreadful ( I think the latter was from Pro’s so not really fair )…
Strangely I found some on ebay that were clones for £9.99. So I ordred two!! days later ebay informed me the Member is no longer on ebya etc… So still waiting on paypal to resolve… Anyway I had not spotted they were only 110V so would have been a pain anyway.
I found a UK seller of the Genuine (who knows if it is or not!) unit for ~£60 and purchased that.
Not sure this is the same seller but this is the item…
It arrived 2 days later and hte box was of sufficient quality to reasure me that it was not total junk.
The Device is marketed as a SMD rework station, but at present I am not at the stage of working with SMD. But the hot air gun that’s part of the unit is good for general heat work like heat shrink.
The unit basicaly comprises
Temperature Controlled Iron
Heat Gun
Variable PSU
Volt Meter.
I have been using the iron over the last couple of weeks to do some general repairs on a Yamaha DX21 and it’s quite nicly weighted and heats up well. It has enough grunt for large guagestuff as well and comes with a wide selection of tips ( probably be unavailable in two years unlike Antex stuff ). I have also done a few other jobs like the pin headers on an arduino nano and it provides a lot more confidence than the older irons. My son is presently building 20 DMX cables and has not complained or asked me to do it!
480C is the max temp on both heat sources with 100 and 200 being the low point for Air/Iron respectivly.
Supposedly there is a calibration option, I don’t have an independent temperature sensor that goes to 480C to hand.
The heat gun I have used a couple of times, I think this will require a lot of getting used to as I was practicing on an old PCB and the track seemed to be bubbling!!! But I am sure it will come in useful.
The power supply bit seems ok, I am not sure how accurate the output is compared to the setting as it did not seem to match what my Fluke was saying at lower voltages.
And finally the test meter I have not bothered with yet, it’s a shame that you can’t use the PSU and meter at the same time.
It will display Fahrenheit for those that can understand it… (all I know is that at 451f is supposedly the ignition point of paper… )
Overall for the money it seems to be a reasonable entry level iron for the more serious amateur. I certainly won’t be usign the old irons except in unusual circumstances.
I do have two complaints about it.
there is no solder roll dispenser, this is a pain when you knock the roll over and the cat plays chase…
the cord on the iron is a little short, the base unit is quite large and has to be kept within about 50cm of the work area to allow for flexibility of movement…
