Hi there, I just started building this module and wanted to let you know that it seems the BOM on GitLab has C20 and C19 swapped. On the PCB, C19 is 1nF and C20 is 47pF, which seems to be correct based on the footprints and the Tayda parts listed in the BOM.
Also tagging @danbass since I believe he will soon be building one as well.
Thanks for the heads up, but it’s the PCB that’s wrong and the BOM is right.
The footprints are right, the Tayda part numbers are right. Only problem is the reference numbers on the PCB silkscreen are swapped. The values on the PCB are correctly placed.
I was dreading yanking it out of the synth case to see if I assembled it right but turns out I did take a photo of the assembled board, and yes, I did assemble it right! I was going by the values and not the reference numbers.
I’ll fix it and post it to GitLab soon. Thanks again.
[Corrected:]
