I do not want to clutter the Verified Stripboards space with my inexperienced questions, so am going to refer back to Verified Stripboard Layouts! - #215 by BlackDeath here. ![]()
I’ve built this module, trying to replace an amplifier module I made when starting out (using a TL072 mixing module in the hopes that running signal through the OpAmp would make it louder).
This is all for the purpose of increasing the amplitude of my audio and CV signals so that my triangle and square waves sound close to the loudness of my saw waves, and so that effects such as filter cutoffs are manipulated on a bigger scale.
Unfortunately, neither of these modules make the signal any louder, meaning that it now just acts as a passive attenuator. Am I missing something? Would the pot I have placed after the circuit reduce the amplitude back down even if it is turned all the way up? Might I need to disconnect this from ground (left pin) to allow the signal to be louder?
Thank you all!
