I made this simple noise circuit for drum sounds:
On my testing bench, I use +/-15V supply (because I don’t have +/-12V supply).
I tried with 2N2222A, and everything was fine, my drum module was working well!
So I moved it into my case, where I have a +/-12V supply. And (“Oh surprise!”), no sound out of the module! A bit puzzled, I went back to my bench, made a sketchy contraption to power my module in a more controlled manner, and decreased the input voltage gradually, while monitoring the noise output.
15V: Good
14V: A bit less, but still good
13V: A bit less
12V: Nothing at all, D’oh!
Well, crap.
I then tried with S9013 transistors. And it worked down to ~9V!
So yeah I thought it could be a good resource to have here, if you have other examples where not-all-transistors-works-but-I-don’t-really-now-why. (I know there is a lot of issues with the SSO for example, but this one already have a full thread)
