As a sort of reply to mightywombat’s thread about simple piano kbd, having a similar “problem” but with a twist.
The twist is a bunch of touch buttons (see pic). Bunch = 50+ pieces.
They were very cheap (AliExpress) and that was the main reason I ordered them, but with no clear ideas how/where to use them.
Due to their simple function (strappable active on/off …) and easy to acticate I had an idea of some kind of ribbon controller.
The issue are the OPs of the small modules - how to make the 50+ outputs into something more binary (or analog)??? I could use a number of ultrasmall relays (Reed relay 5V) or use the priority encoder I mentioned in Mightywombats thread.
Also the modules seems to be activated from underside as well , so mounting them requires some planning.
Here’s a typical picture of a typical module. It is approx 1/2" by 1/2".
These modules are sold cheaply from several sellers on AliX and some 50 of them is well under 10 USD. They can be used elsewhere as well.
