Well this sure is a… special sketch.
There’s a very odd thing where it actually goes into the ‘correct guess’ sequence on startup. I’ve made a few minor changes to get rid of it, you can try this. But honestly, this thing is so convoluted, I might have ended up ruining it. Obviously I don’t have to system to test it on. It’d be helpful if you could post the serial monitor output alongside the sketch, so we can see what it’s actually doing.
//Code Breaker
//Michael Klements
//The DIY Life
//15 May 2020
//Encoder interrupt routine adapted from Simon Merrett's example code
#include <SPI.h> //Import libraries to control the OLED display
#include <Wire.h>
#include <Adafruit_GFX.h>
#include <Adafruit_SSD1306.h>
#include <Servo.h> //Import library to control the servo
Servo lockServo; //Create a servo object for the lock servo
#define SCREEN_WIDTH 128 // OLED display width, in pixels
#define SCREEN_HEIGHT 32 // OLED display height, in pixels
#define OLED_RESET -1 // Reset pin # (or -1 if sharing Arduino reset pin)
Adafruit_SSD1306 display(SCREEN_WIDTH, SCREEN_HEIGHT, &Wire, OLED_RESET); // Declaration for an SSD1306 display connected to I2C (SDA, SCL pins)
static int pinA = 2; //Hardware interrupt digital pin 2
static int pinB = 3; //Hardware interrupt digital pin 3
volatile byte aFlag = 0; //Rising edge on pinA to signal that the encoder has arrived at a detent
volatile byte bFlag = 0; //Rising edge on pinB to signal that the encoder has arrived at a detent (opposite direction to when aFlag is set)
volatile byte encoderPos = 0; //Current value of encoder position, digit being input form 0 to 9
volatile byte prevEncoderPos = 0; //To track whether the encoder has been turned and the display needs to update
volatile byte reading = 0; //Stores direct value from interrupt pin
const byte buttonPin = 4; //Pin number for encoder push button
byte oldButtonState = HIGH; //First button state is open because of pull-up resistor
const unsigned long debounceTime = 10; //Debounce delay time
unsigned long buttonPressTime; //Time button has been pressed for debounce
byte correctNumLEDs[4] = {9,12,7,11}; //Pin numbers for correct number LEDs (Indicate a correct digit)
byte correctPlaceLEDs[4] = {6,10,8,13}; //Pin numbers for correct place LEDs (Indicate a correct digit in the correct place)
byte code[4] = {0,0,0,0}; //Create an array to store the code digits
byte codeGuess[4] = {0,0,0,0}; //Create an array to store the guessed code digits
byte guessingDigit = 0; //Tracks the current digit being guessed
byte numGuesses = 0; //Tracks how many guesses it takes to crack the code
boolean correctGuess = false; //Variable to check whether the code has been guessed correctly
void setup()
Serial.begin(9600); //Starts the Serial monitor for debugging
lockServo.attach(5); //Assign the lock servo to pin 5
delay(20);
lockServo.write(45); //Locks the safe when turned on
if(!display.begin(SSD1306_SWITCHCAPVCC, 0x3C)) //Connect to the OLED display
Serial.println(F("SSD1306 allocation failed")); //If connection fails
for(;;); //Don't proceed, loop forever
display.clearDisplay(); //Clear display
for(int i=0 ; i<=3 ; i++) //Define pin modes for the LEDs
pinMode(correctNumLEDs[i], OUTPUT);
pinMode(correctPlaceLEDs[i], OUTPUT);
pinMode(pinA, INPUT_PULLUP); //Set pinA as an input, pulled HIGH to the logic voltage
pinMode(pinB, INPUT_PULLUP); //Set pinB as an input, pulled HIGH to the logic voltage
attachInterrupt(0,PinA,RISING); //Set an interrupt on PinA
attachInterrupt(1,PinB,RISING); //Set an interrupt on PinB
pinMode (buttonPin, INPUT_PULLUP); //Set the encoder button as an input, pulled HIGH to the logic voltage
randomSeed(analogRead(0)); //Randomly choose a starting point for the random function, otherwise code pattern is predictable
display.setTextColor(SSD1306_WHITE); //Set the text colour to blue
startupAni(); //Display the startup animation
generateNewCode(); //Calls function to generate a new random code
void loop()
if(correctGuess) //Code between games to reset if the guess is correct, initially true to open safe and then generate new code
delay(300);
updateLEDs (0,4); //Flashing LED sequence
delay(300);
updateLEDs (4,0);
delay(300);
updateLEDs (0,4);
delay(300);
updateLEDs (4,0);
delay(300);
updateLEDs (4,4); //Turn all LEDs on
lockServo.write(140); //Unlock the safe
display.clearDisplay(); //Clear the display
display.setTextSize(1); //Set the display text size to small
display.setCursor(35,10); //Set the display cursor position
display.print(F("In ")); //Set the display text
display.print(numGuesses); //Set the display text
display.setCursor(35,20); //Set the display cursor position
display.print(F("Attempts")); //Set the display text
display.display(); //Output the display text
delay(5000);
display.print(F("Push to")); //Set the display text
display.print(F("Start")); //Set the display text
display.setTextSize(2); //Set the display text size back to large
boolean lock = false; //Safe is initially not locked
boolean pressed = false; //Keeps track of button press
while(!lock) //While button is not pressed, wait for it to be pressed
byte buttonState = digitalRead (buttonPin);
if (buttonState != oldButtonState)
if (millis () - buttonPressTime >= debounceTime) //Debounce button
buttonPressTime = millis (); //Time when button is pressed
oldButtonState = buttonState; //Remember button state
if (buttonState == LOW)
pressed = true; //Records button has been pressed
else
if (pressed == true) //Makes sure that button is pressed and then released before continuing in the code
lockServo.write(45); //Lock the safe
display.setCursor(30,10); //Set the display cursor position
display.print(F("Locked")); //Set the display text
lock = true;
updateLEDs (0,0);
correctGuess = false; //The code guess is initially set to incorrect
numGuesses = 0; //Reset the number of guesses counter
inputCodeGuess(); //Calls function to allow the user to input a guess
numGuesses++; //Increment the guess counter
checkCodeGuess(); //Calls function to check the input guess
encoderPos = 0; //Reset the encoder position
guessingDigit = 0; //Reset the digit being guessed
codeGuess[0] = 0; //Reset the first digit of the code
updateDisplayCode(); //Update the displayed code
void updateDisplayCode() //Function to update the display with the input code
String temp = ""; //Temporary variable to concatenate the code string
if(!correctGuess) //If the guess is not correct then update the display
for (int i=0 ; i<guessingDigit ; i++) //Loops through the four digits to display them
temp = temp + codeGuess[i];
temp = temp + encoderPos;
for (int i=guessingDigit+1 ; i<=3 ; i++)
temp = temp + "0";
Serial.println(temp); //Output to Serial monitor for debugging
display.setCursor(40,10); //Set the display cursor position
display.println(temp); //Set the display text
display.display(); //Update the display
void generateNewCode() //Function to generate a new random code
Serial.print("Code: ");
for (int i=0 ; i<= 3 ; i++) //Loops through the four digits and assigns a random number to each
code[i] = random(0,9); //Generate a random number for each digit
Serial.print(code[i]); //Display the code on Serial monitor for debugging
Serial.println();
void inputCodeGuess() //Function to allow the user to input a guess
for(int i=0 ; i<=3 ; i++) //User must guess all four digits
guessingDigit = i;
boolean confirmed = false; //Both used to confirm button push to assign a digit to the guess code
encoderPos = 0; //Encoder starts from 0 for each digit
while(!confirmed) //While the user has not confirmed the digit input
buttonPressTime = millis (); //Time when button was pushed
oldButtonState = buttonState; //Remember button state for next time
codeGuess[i] = encoderPos; //If the button is pressed, accept the current digit into the guessed code
pressed = true;
else
if (pressed == true) //Confirm the input once the button is released again
updateDisplayCode(); //Update the code being displayed
confirmed = true;
if(encoderPos!=prevEncoderPos) //Update the displayed code if the encoder position has changed
prevEncoderPos=encoderPos;
void checkCodeGuess() //Function to check the users guess against the generated code
int correctNum = 0; //Variable for the number of correct digits in the wrong place
int correctPlace = 0; //Variable for the number of correct digits in the correct place
int usedDigits[4] = {0,0,0,0}; //Mark off digits which have been already identified in the wrong place, avoids counting repeated digits twice
for (int i=0 ; i<= 3 ; i++) //Loop through the four digits in the guessed code
for (int j=0 ; j<=3 ; j++) //Loop through the four digits in the generated code
if (codeGuess[i]==code[j]) //If a number is found to match
if(usedDigits[j]!=1) //Check that it hasn't been previously identified
correctNum++; //Increment the correct digits in the wrong place counter
usedDigits[j] = 1; //Mark off the digit as been identified
break; //Stop looking once the digit is found
for (int i=0 ; i<= 3 ; i++) //Compares the guess digits to the code digits for correct digits in correct place
if (codeGuess[i]==code[i]) //If a correct digit in the correct place is found
correctPlace++; //Increment the correct place counter
updateLEDs(correctNum, correctPlace); //Calls a function to update the LEDs to reflect the guess
if(correctPlace==4) //If all 4 digits are correct then the code has been cracked
display.setCursor(20,10); //Set the display cursor position
display.print(F("Cracked")); //Set the display text
correctGuess = true;
else
void updateLEDs (int corNum, int corPla) //Function to update the LEDs to reflect the guess
for(int i=0 ; i<=3 ; i++) //First turn all LEDs off
digitalWrite(correctNumLEDs[i], LOW);
digitalWrite(correctPlaceLEDs[i], LOW);
for(int j=0 ; j<=corNum-1 ; j++) //Turn on the number of correct digits in wrong place LEDs
digitalWrite(correctNumLEDs[j], HIGH);
for(int k=0 ; k<=corPla-1 ; k++) //Turn on the number of correct digits in the correct place LEDs
digitalWrite(correctPlaceLEDs[k], HIGH);
void startupAni ()
display.println(F("Charlie")); //Set the display text
delay(700);
display.setCursor(45,10); //Set the display cursor position
display.println(F("and")); //Set the display text
delay(700);
display.println(F("Mike")); //Set the display text
delay(700);
display.println(F("Crack")); //Set the display text
delay(700);
display.println(F("the"));
display.display();
delay(700);
display.println(F("Code"));
display.display();
delay(700);
void PinA() //Rotary encoder interrupt service routine for one encoder pin
cli(); //Stop interrupts happening before we read pin values
reading = PIND & 0xC; //Read all eight pin values then strip away all but pinA and pinB's values
if(reading == B00001100 && aFlag) //Check that we have both pins at detent (HIGH) and that we are expecting detent on this pin's rising edge
if(encoderPos>0)
encoderPos --; //Decrement the encoder's position count
else
encoderPos = 9; //Go back to 9 after 0
bFlag = 0; //Reset flags for the next turn
aFlag = 0; //Reset flags for the next turn
else if (reading == B00000100) //Signal that we're expecting pinB to signal the transition to detent from free rotation
bFlag = 1;
sei(); //Restart interrupts
void PinB() //Rotary encoder interrupt service routine for the other encoder pin
if (reading == B00001100 && bFlag) //Check that we have both pins at detent (HIGH) and that we are expecting detent on this pin's rising edge
if(encoderPos<9)
encoderPos ++; //Increment the encoder's position count
else
encoderPos = 0; //Go back to 0 after 9
else if (reading == B00001000) //Signal that we're expecting pinA to signal the transition to detent from free rotation
aFlag = 1;
Yeah 9V batteries suck. If you know that, why did you design it this way? Anyway, a big cap across the powerlines can help smooth this out. Or, if that’s not enough, LiPo cells (= powerbanks) can deliver much more current.
[edit] also, for debugging, the correct code is written to the serial monitor, so you can read it from that. Or, if you will, you can comment out the generateNewCode(); I’ve put on line 72, so the initial code is always 0000
