Ok, so I am making a precision adder to allow me to create larger sequences from my #2001 Keyboard Sequencer and Evil Eye sequencers.
The idea being that I can take the CV out of one, tuned to a root note, and add the CV from the other (clocked at a different division) to provide musical arppegios around that root note. As such my adder needs to be nice and precise.
I also want to duplicate the functionality of my Doepfer precision adder that I use in Eurorack which has a channel of attenuversion with a normalled voltage of precisely 1v being supplied to each input when they are not in use. However I would like to have that normalled voltage just supplied to the attenuverter input and selectable as 0v, 1v or 2v as I often find by the time I have plugged in a pair of sequencers and a modulation source (usually controlled elsewhere) that I can only ever add or subtract 1v from the final output. This is so I can shift my sequence up or down a pair of octaves separately from their original source, allowing me to derive, say, a lead from a bassline etc.
Did the obvious googling and found the information I need to actually create a adder section, no problems there, and know full well how to create a nice precision attenuverter, added some buffering to the input of the attenuverter channel (to keep all my input impedances the same, not sure if it would cause precision issues later on, but it didn’t go pop on the breadboard and signals did made it through - I just havent measured them properly yet so I still don’t know if it was the right thing to do), then through the attenuverter stage and off to the adder and output.
Here is the schematic I have so far…
Now, what I want to do is supply the Input 1 jack socket tip normal (which is currently connected to ground in that schematic - J1TN) to a switch, that would allow me to connect either a 1v, 2v or ground the input (giving me my 0v) to then buffer and attenuvert.
Would Sam’s voltage divider ladder as employed in the #1222 Performance VCO work here, or should I attempt something using a proper reference voltage regulators? Would it be a case of using both methods in combination - say configuring a 3v reference regulator and then deriving the 1v and 2v from that using voltage dividers and buffering the output? I have had references in many a project over the years, but never actually tried to design something myself that has actually got them in, so I am a bit bamboozled with regards to how I should go about this.
Also, would it be a good idea to reconfigure the attenuverter to use a B10k, rather than my goto B100k, so that the rest of the resistors would come down to 10K and match everything else. Well, except the load resistors, they would end up at 4.7k, but thats a whole different thing. I don’t think it should make a difference here, but I am not sure, and it’s too late to go rummaging round with a multimeter.
Any input from you guys would be most appreciated.
EDIT: I am aware I haven’t actually connected the output jack to ground, and that the main power conditioning caps have no value - I’ll rectify that when I am not half asleep. There may be other little drawing errors too, but I wanted to get across what I was doing quickly.
. If you want to stick with your current method of using precision parts (rather than trimming), I’d suggest you use something like an
, your power connector is reversed. Pin 1 should -12V.
