Sorry, thought you were referring to drivers. Lookin into this firmware deal, this specific firmware update can actually be found on the UMC202’s site, but not on the UMC404HD.
I downloaded the firmware and bundled with it came some documentation. This file appears to be the same one referenced by the sweetwater article, but the documentation does not mention windows versions newer than 8.1, and lists the UMC404 which may very well be it’s own distinct product.
I’d say flash this firmware at your own risk, but it seems at least corroborated by the sweetwater article. It also appears this firmware is used for many of their audio interfaces, and the lack of inclusion of the UMC404HD from the hardware support could simply be a result of the product releasing after the document’s creation.
Checking my own device, it appears to be this firmware version already. Can you check your UMC control panel and screenshot it for posterity? I just want to note that @foorje who originally made this thread because they were having issues despite working with v1.12 revision.
Just to add, this weekend I used this interface with an Ubuntu based distro and the kernels drivers worked immediately no problem.
I think you might be into something with the firmware deal, since some people could receive hardware preflashed with the current firmware, and others could be not so lucky or have an older product.
This seems like it might be the key. I’ll keep looking into it and check back here to see if any progress has been made. I’ll also reach out to Behringer support to see what is going on.
Fashionably slow as always. I got a chromebook and a macbook pro early 2008 now to also test on. Will do some tests this weekend and see what they do. The chromebook is dual boot (chromeOS/lubuntu) and the macbook is linux (mint). I can probably even try to hook it up to my phone. We’ll see what happens then.
Also just a quick thank you to everyone who has so far tried to weigh in on this thread. The problem seems to be common enough that it probably warrants some kind of official diagnosis from Behringer but I doubt we’ll get that anytime soon.
Another big pause, I just tried it with the chromebook. It works… pretty much flawlessly with that. No pops or crackles, no problems. Alsamixer seems to pick up pretty much all the in and outputs too.
At this point I’d either chalk it up to my computers USB, windows fuckery, or some kind of weird ground interference.
Unfortunately not a real solution but it’s some kind of closure at least.
Edit: I did install the new drivers from Behringer and those made no difference. However they did add some more in/output combos in windows which is nice.
I have unfortunately not been able to fix my issues with the behringer. Therefore it’s now relegated to being used just for inputs (mics etc). I’m using a fiio dac/amp as my output now.
THIS helped in my case. Thank you!
Turning off power saving on every USB bus possible:
Disable USB Power Management
Disabling the USB power management allows you to free up bandwidth on the USB bus, which will help with device recognition and driver installation issues. To turn it off, follow the steps below:
Open the Control Panel
Click on Hardware & Sound
Click on Device Manager under the Devices and Printers section
Click the triangle next to Universal Serial Bus Controllers
Double-click on the first USB Root Hub item
Click on the Power Management Tab
Uncheck the box that says “Allow the computer to turn off this device to save power” and click OK
Do this for all USB Root Hub and Generic USB Hub items
Hey, awesome of you to share this! Weirdly enough I don’t seem to have any problem at all right now. I have resorted to trying a BIOS update or 2, maybe that fixed it? If it pops back up I’ll be sure to try your fix.
I was going crazy trying to find a fix, and found the solution recently for the popping sounds I was getting with the UMC 404HD. The fix was to use the external power supply. Since doing that it has worked great. I’m using a Dell XPS 15 9539 running Windows 11 and Studio One 6 DAW.
Does anyone have a working link for the UMC404 (non-HD) firmware v1.12 update? The official Behringer link is dead, and I’ve been searching for hours with no luck.
I’m currently on firmware v1.02 and experiencing constant crackling and dropouts on older Intel USB controllers (confirmed on a 2015 MacBook Pro and multiple older Windows laptops), while the interface works perfectly on newer machines. According to Sweetwater, firmware v1.12 fixes exactly this issue.
If anyone still has the file archived, could you please share it? A quick rundown of the update procedure would also be hugely appreciated.
Thanks in advance!
UPDATE: After searching for nearly a day, I managed to find the file and figure out how to update it. All the issues are resolved. Feel free to reach out to me if you find yourself in the same situation—I’ve saved the archives and won’t be deleting them
