I want to add a hard reset button to a 4017 sequencer. Therefore, I am studying the datasheet to figure out the minimum and maximum voltage that can be applied to the reset pin (https://www.ti.com/lit/pdf/schs027). Page 4 of the datasheet shows the dynamic electrical characteristics, but the data on the reset operation somewhat confuse me. It shows Vdd of 5, 10, and 15 V, with nano second time limits. How should I interpret this? Can I simply use a 12V with a momentary switch? Or do I need a small circuit to limit the pulse time to not exceed the limit listed in the datasheet for the voltage used?
