If your trimmer is 100R 400R instead of 100k you might get something like 3.3V there.
EDIT:corrected bad math.
Update: I swapped out the LM4040AIZs on all my oscillators after upping the resistors to 4K7. After testing for a few hours, the wobble is gone for me. On to the next gremlins and maybe some music!
After a couple of days since I swapped mine, I also have stability again!
Good to know as I’ll start building next week-end.
So up from 220R to 1K to 4K7.
I’m sticking with 1K for now, but sure if 4K7 works, why not?
I wonder why the 1222 outputs are not terminated with resistors to gain 1k impedance, as the kosmo specs say.
Is this already done by the 3340 IC?
The “spec” is more guidelines than spec, Sam especially is free to do whatever the hell he likes.
We tried to capture what he has been doing in the “spec” wiki so that other designers can have a chance at being compatible.
The 1K output resistor is more for output short circuit protection than for impedance matching.
(1K outputs and 100K inputs are fundamentally mismatched impedances by “spec”, but at audio frequency it doesn’t matter.)
Mismatched for power transfer, indeed, but for voltage transfer you want output ≪ input to maximize the voltage and minimize the current (i.e. bridging, not matching).
(the TL07x’s output stage has an internal resistance of around 200-300 ohm iirc, but the effective output impedance depends on gain)
And as has been discussed elsewhere, a TL07x can survive a short to ground or either rail indefinitely. Still, 100R to 1k output resistors are so common, their absence is a little surprising. You could always add them on the output jacks, of course.
Hello there!
I’ve built a couple of the Kosmo Modules already and they all work great but I’m running into issues wit the VCO. I’ve bought two but have assembled only one so far and it doesn’t work as in: no sound comes from the outputs and the display and LEDs are unresposive.
When I use the Code from SAM the LEDs and Display just stay blank when connected to my power source. When I use the updated Code from Jos Bouten the LEDs just light up constantly and so does the whole display. So at least I know those components are working and I guess the Arduino isn’t the problem as well.
I’ve reflowed every single component as that was a problem with an earlier build I had. I also turned the Potentiometers all they way in every direction (as that was the problem with my LFO build) but to no avail.
I’ve used a multimeter at the test point where it says “4V” but I only get some very small mv number there.
As I’m a beginner when it comes to electronics and haven’t had to troubleshoot anything serious yet I’m a bit stumped and could use some guidance as to what might be wrong / which components I should test and how.
Any help is very much appreciated
Thanks!
Ben
If you don’t have ~4V at the test point, you can start with this comment a few posts above, replacing “3.3V” by “a few mV”
Until you get that 4V fixed, at best your oscillator will be stuck at the lowest octave setting. You can try feeding some control voltage on the 1V/oct input, to determine if the rest of the oscillator is alive.
You should get at least some very low oscillations (possibly even sub audio).
Until the oscillator works properly in the audio range, there is no point in trying to debug the tuner circuit.
Thank you for your help mate!
I now got my ~4V at the test point but I still can’t get any audio to play. I tried the trimpot “ctrl” (RV6) and also the octave and fine tune knobs but nothing changed at all. If it’s too low of a sound I think I might just not hear anything as I currently only have a very shitty speaker connected to it. What should I test next to see where the problem might lie?
This:
Thanks again for the next steps, but I’m a bit stumped now as to what the hell is going on. Here is what I’ve done:
I’ve changed the Resistor on R42 from a 220R to a 4,7k as recommended in the other thread.
I’ve tested the resistor values from the trimpots to pin 15 and found out that it’s all measuring around 50-60k instead of 100k but I don’t understand why. If I measure the 100k resistors on R23 & R24 I get 55k / 58k
The 100k resistors on R25 & R19 measure the correct 100k
But they’re all from the same batch. Does this mean those two are just faulty? Or does it measure something else with it as they are already on the board (heard something like that a while back but not sure about it)
So now I’m wondering if I should swap out those 2 resistors or the ICs to proceed. Sorry for being kind of high maintenance but I’m really eager to get this thing running. I’ve built 6 other modules (LFO, Mixer, MIDI to CV, Splashback Delay, Filter, Envelope Generator) and they all work fine, but I was really looking forward to finally generate some actual sound with my box -_-
EDIT: Forgot to add: I’ve hooked it up to my audio interface and could confirm that there is zero sound coming out of the module unfortunately
Yes, it’s problematic measuring resistors in a circuit. R23 is in parallel with R24 plus the lower parts of pots RV6 and RV7, and vice versa, so you’d expect to measure something less than 100k for either of them. They’re almost certainly fine. They’re certainly within the right ballpark so would not cause the problems you’re seeing. Move on to checking the voltages as described.
Thanks, that’s what I hoped. I hate de-soldering
The voltages are for the centre almost nothing (a couple of mv), -1V for the “trk” one and almost nothing for the “HF”.
If I turn the centre note trimmer I get no change in voltage, I’ve also just resoldered it again just the be sure but no dice. So I assume the trimpot might be busted and I need to swap it?
How are you measuring the voltage? Red probe on the stated point and black probe where?
What voltages do you measure on the two ends of the center note trimmer?
Yes red probe on the points, black is on ground (I use the jack connector part of it as it’s easy to hold it in place there - jacks are disconnected at the moment)
I get 12V on the “left” or “down” point of the center note trimmer (seen from the back, so the one where there is no screw to change the trimmer)
And I just realized that the one in the middle is changing, so I’ve been measuring the wrong one? I assumed “on the trimmer/knob side of the 100k.” means on the pin where the screw is
EDIT: Sorry forgot the values. I had ~0.8V, turned the trimmer a good amount and got it to ~3V next
As I have a second PCB and enough components I’m thinking about just building a second one for now. Can I just build the Oscillator parts and keep the tuner parts (especially the Arduino) out? If so, what components would I need to solder on to get just the Oscillator going?
My thinking is - if I can get the second one going I can check each values / components to troubleshoot the first one
hey ben!!! sorry your having such troubles! to answer your question I have highlighted the bits you can miss out to just get the oscillator going . you can even skip the octave switch if you want (highlighted in green) to see if it will actually work. (all tuner things are in grey you can skip them all)
