Looks super interesting - I’m going to have to take a deeper look when I have some more free time, that’s for sure.
One thing on the V/Oct trim. The way I did it, and have seen it done, is to put the trimming on the output of the inverting summer amp that has the thermal resistor in the feedback path which I think will buffer the CV inputs. I’m not sure but I think you may get different trimming interactions depending on what’s plugged in to your CV jacks with your current config.
Also check out http://www.openmusiclabs.com/files/expotemp.pdf - section IV. T HERMISTOR COMPENSATION
That shows a PTC in feedback. If you want to use an NTC - check out @jkb’s post with some references here;
Cheers,
Jared
