The Psych-Tone Random Music Generator
Enjoying my breakfast and midday lunch (and often evening meal) watching crazy YT-videos, I watched through a series of LMNC’s videos. Today I watched the video about the T2000 repair and the Psych-Tone and was surprised I couldn’t find any info on the latter in here, so I decided to write a few notes, even though, my plans to build one were laid to rest in mid 70s.
My early history
In my younger days I regularly bought Popular, Practical and Radio Electronics and when reading about the Psych-Tone and when I finally ended up at the tech college in Linköping, Sweden, I managed to trace the PCB with curve tape and the round tape-pads and a friend who had connections to people at DATASAAB (SAAB had three divisions back then - cars, airplanes and computers!!!) got me a nice etched board that I drilled and then put aside, due to components (the rotary switches).
Today
Since then I have always been into electronics and always looking for cool musical or sound projects but it isn’t til now I have the time. Anyway, the Psych-Tone is a cool device and may be, as LMNC showed in the video used partially for other projects.
Sources
First of all, the journal, Popular Electronics, Feb 1971, can be picked up at World Radio History, where many many journals and booklets can be found.
I must say that building an ORIGINAL Psych-Tone won’t be easy as it uses RTL (Resistor-Transistor-Logic, a precursor to TTL - Transistor-Transistor-Logic) and those chips are either impossible to find or VERY expensive. Convertying the thing to CMOS is a better idea. Also, I guess some of the transistors are hard to find (I’ve got the transistor kit :yum:). But once again, what’s cool is the, what was it called? TUNE COMPUTER. The sound-making circuits can be replaced by a synthesizers VCO, VCF, ADSR and VCA.
Tune Computer
The tune computer is actually a slowly clocked PRNG - Pseudo Random Noise Generator - made up by a shiftregister with a feed back signal generated by EXOR-gates hooked up to the shiftregister’s outputs.
Here’s a typical noise generator made from this design (ETI 46000 synth):
Also the noise IC, used here and there (MOOG MG-1) - MM5837 - is based on the PRNG.
This circuit generates a string of 1s and 0s that sounds very much random - noisy. The chain of registers can be made longer and the longer the more “random” will the resulting noise signal be. There are also guidelines showing how and where to attach the feedback gates, but I just point you to some sources describing the principle:
Pseudo-Random Noise; Using it and How to Create it
Pseudo-Random Noise Generator
Pseudo Random Noise Source
Schakelingen: pseudo random noise generator Dutch
Digital Noise Generator
Further deep diving into the WWW-ocean may reveal yet more fun stuff and more info how to arrange the feedback for a larger chain.
Back to the Original
As noted above the ICs used - MC799, MC791 and MC724 - are hard to find and/or extremely expensive. Besides they run on an odd voltage of 3.6V.
The flip-flops ( :sandal: :sandal:) are used as shiftregisters and the *-gate that either is a NOR, a NAND or MAYBE-gate, constitute the EXOR-gate.
And On To A Modernized Version
A more up-to-date approach would be to use CMOS flips and flops - CD4013 or CD4027 - or go for a shiftregister like CD4094 (or why not a CD4006?!) and a 4070 EXOR-gate.
Here’s a drawing I picked up, signed PHOBoSapiens that shows a complete Tune Computer using more modern components.
This can definitely be another (simpler) random sequencer than for example the Thuring Machine or the 1l/lfinite Melody module I will add to my modular synth.
Hope this triggers some of you to go furter.
I had a strong sense of deja vu watching that video. I don’t remember specifically, but I certainly was reading Popular Electronics, if not in 1971 then within a couple years after and probably going through the library’s back issues. So I think it’s likely I saw the article, but as I said, strong deja vu, which leads me to think I might have been seriously considering building one. I didn’t, but in 1977 I did build another Poptronics project, the PAiA Gnome synthesizer.
The above diagram comes from this EM thread which however doesn’t have a whole lot else, unfortunately.
Thanks for this update! Interesting…
Forgot to share the links to the Youtube video … videos!!!
SWTPC PSYCH TONE - Super Rare 70’s Programmable Synthesizer. Explored and Re-imagined
SWTPC PSYCH TONE - Displaying a rare 70’s programmable synthesiser
Oh this takes me back! Too far. Good links though. Many thanks.
I know what you mean about deja vu though. One of Sam’s everyday electronics posts reminded me I still own the component ruler and leg bender giveaways that were taped to the cover.
The leg bender is awsome, though mine was lost and I bought me a new one. I mostly use PCBs made by myself (with the help of a Chinese factory), so all distances are n*0.1", and the bender is made for this.
I want to give some more info on the PNG. Remembering one of the great Application Notes from Motorola, describing the principle of the Pseudo Noise Generator, I knew what this was all about - mafflema … muthleemut … mathemeetics … darn! … you know plus and minus and the difficult ones: multupl … oh, never mind.
This kind of stuff can be represented in formulas (I was trying to decode them yesterday evening) and be broken down to circuits using shift registers and EXOR-gates.
I will link to three pages describing this more in detail, but condensing the soup into a bouillon cube this can be said said about the principle:
(1) Use any length of a shift register and EXOR-gates that will form a feedback path for the shift register.
(2) The longer the shift register the less “pseudo”, or, a long SR will make the pseudonoise yet more random (repeating the sequence more seldom)
(3) The SR has to be tapped at specific positions to get the required randomness.
Here’s the papers:
Pseudo noise sequences tor engineers
PN Sequence Generator Check “Sequences of Maximum Length”
Linear-feedback shift register
