Need help with an Rpi Pico
Hello,
I am not a good programmer at all but I manage to make my accordion keyboard work as far as notes go.
I needed 5 potentiometers to control different parameters so I installed an ADS1115.
It is working perfectly with the test script provided with the lib BUT as soon as I add it to my main code it’s not working at all and give me thius error :
OSError: [Errno 110] ETIMEDOUT
can anyone help me solve this problem?
the lib is here :
the ads1115 function is dacmescouilles(), it works where it is now but I can’t put it in the “while” loop
here is my micropython script :
# Pi Pico MIDI Matrix Decode
# @diyelectromusic
# https://diyelectromusic.wordpress.com/2021/02/03/pi-pico-midi-matrix-decode/
#      MIT License
#      Copyright (c) 2020 diyelectromusic (Kevin)
#      Permission is hereby granted, free of charge, to any person obtaining a copy of
#      this software and associated documentation files (the "Software"), to deal in
#      the Software without restriction, including without limitation the rights to
#      use, copy, modify, merge, publish, distribute, sublicense, and/or sell copies of
#      the Software, and to permit persons to whom the Software is furnished to do so,
#      subject to the following conditions:
#      The above copyright notice and this permission notice shall be included in all
#      copies or substantial portions of the Software.
#      THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
#      IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY, FITNESS
#      FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR
#      COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, WHETHERIN
#      AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM, OUT OF OR IN CONNECTION
#      WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE SOFTWARE.
from machine import Pin, I2C
from machine import ADC
import utime
import midi
from time import sleep
from ads1x15 import ADS1115
#configuration du ADS1115
i2c=I2C(0, sda=Pin(4), scl=Pin(5))
adc = ADS1115(i2c, address=72, gain=1)
def dacmescouilles():
    value = adc.read(0, 1)
    print(value)
dacmescouilles()
#juste la led de la pico
led = Pin(25, Pin.OUT)
#boutons octaves
bout_bass1 = Pin(2, Pin.IN,Pin.PULL_UP) #basses
bout_bass2 = Pin(3, Pin.IN,Pin.PULL_UP) #basses
bout_acc1 = Pin(4, Pin.IN,Pin.PULL_UP) #accords
bout_acc2 = Pin(5, Pin.IN,Pin.PULL_UP) #accords
#potards
adc_pin_bend = Pin(28, mode=Pin.IN)
bend = ADC(adc_pin_bend)
#uart = UART(0,31250)
#librairie midi
my_midi = midi.Midi(0,Pin(0),Pin(1))
velocity = 127
note=48
debounce_gate=5
# tentons de faire un tableau de commande
grille_basses_noms=[
    ["fa","do","sol","re","la","mi",
     "si","fad","dod","lab","mib","sib",
     "Afa","Ado","Asol","Are","Ala","Ami",
     "Asi","Afad","Adod","Alab","Amib","Asib"
grille_basses_notes=[
    [                       #### NOTES ###########
     -7,    # FA            #    41   # r=8  c= 13
     0,     # DO            #    48   #      c= 15
     7,     # SOL           #    55   #      c= 11
     2,     # RE            #    50   #      c= 14
     -3,    # LA            #    45   #      c= 10
     -8,    # MI            #    40   #      c= 12
     -1,    # SI            #    47   # r=9  c= 13
     -6,    # FA# / SOLb    #    42   #      c= 15
     1,     # DO# / REb     #    49   #      c= 11
     -4,     # SOL# / LAb    #    44   #      c= 14
     3,     # RE# / MIb     #    51   #      c= 10
     -2,    # LA# / SIb     #    46   #      c= 12
                            #### ACCORDS #########
     5+12,     # fa            #    53   # r=6  c= 13
     12+12,    # do            #    60   #      c= 15
     7+12,     # sol           #    67   #      c= 11
     14+12,    # re            #    62   #      c= 14
     9+12,     # la            #    57   #      c= 10
     4+12+12,  # mi            #    52   #      c= 12
     11+12,    # si            #    59   # r=7  c= 13
     6+12,     # fa# / solb    #    54   #      c= 15
     13+12,    # do# / reb     #    61   #      c= 11
     8+12,     # sol# / lab    #    56   #      c= 14
     15+12,    # re# / mib     #    63   #      c= 10
     10+12     # la# / sib     #    58   #      c= 12
# Details of how to make a keyboard matrix
# http://blog.komar.be/how-to-make-a-keyboard-the-matrix/
firstnote = 48 # C3
rows = []
cols = []
playnote = []
lastnote = []
canal_1 = 1
canal_2 = 1
#ads1115 test
#pitch sur dac du pico pin 28
def midiPitchBend():
    pot_bend = round(bend.read_u16()/4)   # conversion analogique-numérique 0-65535 vers 16384
    msb = pot_bend >> 7
    lsb = pot_bend & 127
    my_midi.send_pitch_bend(224,lsb,msb)
#def midiMwh(z):
    #print("mod wheel = ",mw)
    #my_midi.send_control_change(midi.CHANNEL[z], 91, value=mw)
    #91 attaque? , 13 puissant, 12 subtile
# Switch OFF will be HIGH (operating in PULL_UP mode)
#notes = do re mi fa sol la >> row = 13,14,12,15,11,10 / col = 8
#notes = fa# sol# la# si do# re# >> row = 13,14,12,15,11,10 / col = 9
row_pins = [15,13,11,14,10,12]
numrows = len(row_pins)
for rp in range(0, numrows):
    rows.append(Pin(row_pins[rp], Pin.IN, Pin.PULL_UP))
# OPEN DRAIN mode means that when HIGH the pin is effectively disabled.
# According to the RP2 MicroPython code this is simulated on the RP2 chip.
# See https://github.com/micropython/micropython/blob/master/ports/rp2/machine_pin.c
# WARNING: At time of writing, this isn't in the MP release!
#          For now, just use standard Pin.OUT.
 #accord = 6,7 notes=8,9
col_pins = [8,9,6,7]
numcols = len(col_pins)
for cp in range(0, numcols):
    cols.append(Pin(col_pins[cp], Pin.OUT))
# Initialise Columns to HIGH (i.e. disconnected)
for c in range(0, numcols):
    cols[c].value(True)
    for r in range(0, numrows):
        # initialise the note list
        playnote.append(0)
        lastnote.append(0)
while True:
    # Activate each column in turn by setting it to low
        cols[c].value(False)
        # Then scan for buttons pressed on the rows
        # Any pressed buttons will be LOW
            if (rows[r].value() == False):
                playnote[c*numrows+r] = 1
            else:
                playnote[c*numrows+r] = 0
        # Disable it again once done
        cols[c].value(True)
    # Now see if there are any off->on transitions to trigger MIDI on
    # or on->off to trigger MIDI off
    for n in range(0, len(playnote)):
        if (playnote[n] > 0):
            midiPitchBend()
            #midiMwh(canal_1)
        if (playnote[n] == 1 and lastnote[n] == 0):
            for o in grille_basses_notes:
                print("######################################################################")
                print("note : ",firstnote+o[n])
                if (n < 12):
                    if (bout_bass1.value()==0):
                        my_midi.send_note_on(midi.CHANNEL[canal_1], firstnote+o[n], velocity)
                    if (bout_bass1.value()==1 & bout_bass2.value()==1):
                        my_midi.send_note_on(midi.CHANNEL[canal_1], firstnote+o[n]+12, velocity)
                    if (bout_bass2.value()==0):
                        my_midi.send_note_on(midi.CHANNEL[canal_1], firstnote+o[n]+24, velocity)
                if (n > 11):
                    if (bout_acc1.value()==0):
                        utime.sleep_us(debounce_gate)
                        my_midi.send_note_on(midi.CHANNEL[canal_2], firstnote+o[n], velocity)
                    if (bout_acc1.value()==1 & bout_acc2.value()==1):
                        my_midi.send_note_on(midi.CHANNEL[canal_2], firstnote+o[n]+12, velocity)
                    if (bout_acc2.value()==0):
                        my_midi.send_note_on(midi.CHANNEL[canal_2], firstnote+o[n]+24, velocity)
        if (playnote[n] == 0 and lastnote[n] == 1):
            utime.sleep_ms(10)
            my_midi.send_note_off(midi.CHANNEL[1], firstnote+o[n])
            my_midi.send_note_off(midi.CHANNEL[1], firstnote+o[n]+12)
            my_midi.send_note_off(midi.CHANNEL[1], firstnote+o[n]+24)
        lastnote[n] = playnote[n]
I would be so gratefull
ok, I am stupid. There were 2 buttons and the i2c channel on the same pins
don’t be too hard on yourself.
you know you are a pro developer when you feel productive after successfully hunting one chahracter for three days… :slight_smile:
(edit: from personal xp)
I don’t think we would have spotted that :slight_smile:
I didn’t even look as it’s Python and I have no experience of it, but now we know the issue it’s clearly there in the first 20 lines where pins 4 & 5 are declared twice.
Thanks for the sympathy.
It happened because i unpluged the switches to test the adc. 24h appart. As the higher part of the declarations were working (in my mind) i blamed the adc board and didn’t look close enough to the top of the code. Until i starter to duplicate line by line.
It was sorted rather quickly.
:hand_with_index_finger_and_thumb_crossed:
Hello,
I am once more in need of your help,
Everything is working fine on my accordion keyboard, pitchbend, modulation etc all connected to pots. But I cannot find a way to make the aftertouch erp channel to work at all.
I am using the sensai7 midi lib for micropython. From what I understand it should work properly. It is even recognized in midisnoop but there is no effect on the sound of the synt I want to control. No matter if I put the aftertouch before everything, before the note on or after.
Is there a specificity of this midi message I don’t respect?
here is the code :
# @diyelectromusic
#      MIT License
import utime
import midi
i2c=I2C(1, sda=Pin(26), scl=Pin(27))
#boutons octaves
bout_bass1 = Pin(19, Pin.IN,Pin.PULL_UP) #basses
bout_bass2 = Pin(18, Pin.IN,Pin.PULL_UP) #basses
bout_acc1 = Pin(16, Pin.IN,Pin.PULL_UP) #accords
bout_acc2 = Pin(17, Pin.IN,Pin.PULL_UP) #accords
bout_midi1 = Pin(20, Pin.IN,Pin.PULL_UP) #midi
bout_midi2 = Pin(21, Pin.IN,Pin.PULL_UP) #midi
#potards
#librairie midi
velocity = 127
note=48
debounce_gate=10
     -5,    # SOL           #    55   #      c= 11
firstnote = 48 # C3
rows = []
cols = []
playnote = []
lastnote = []
# MIDI
canal_1 = 1
canal_2 = 2
def bouton1(x):
    if (bout_midi1.value() == 1):
        x = 1
    if (bout_midi1.value() == 0):
        x = 2
    return (x)
def bouton2(y):
    if (bout_midi2.value() == 1):
        y = 2
    if (bout_midi2.value() == 0):
        y = 1
    return (y)
def midiPitchBend(x):
    msb = pot_bend >> 7
    my_midi.send_pitch_bend(223+x,lsb,msb)
def mod_wheel(x):
    vMW = round(adc.read(7, 3)/206)
    my_midi.send_control_change(midi.CHANNEL[x], 1, value=vMW)
    return(vMW)
def mod_13(x):
    v13 = round(adc.read(7, 2)/206)
    my_midi.send_control_change(midi.CHANNEL[x], 13, value=-v13+127)
    return(v13)
def mod_91(x):
    v91 = round(adc.read(7, 1)/206)
    my_midi.send_control_change(midi.CHANNEL[x], 91, value=v91)
    return(v91)
def mod_64(x):
    v64 = round(adc.read(7, 0)/206)
    my_midi.send_control_change(midi.CHANNEL[x],64, value=v64)
    #my_midi.send_channel_aftertouch(midi.CHANNEL[x],amount=v64)
    return(v64)
def mod_aftertouch(x):
    my_midi.send_channel_aftertouch(midi.CHANNEL[x],amount=40)
col_pins = [9,8,6,7]
    cols[c].value(True)
        playnote.append(0)
        lastnote.append(0)
while True:
            else:
        cols[c].value(True)
            #mod_aftertouch(canal_1)
            #mod_aftertouch(canal_2)
            #print( "ouaich midi ",  canal_1,canal_2)
            midiPitchBend(canal_1)
            midiPitchBend(canal_2)
            mod_wheel(canal_1)
            mod_13(canal_1)
            mod_64(canal_1)
            mod_91(canal_1)
            mod_wheel(canal_2)
            mod_13(canal_2)
            mod_64(canal_2)
            mod_91(canal_2)
            canal_1 = bouton1(canal_1)
            canal_2 = bouton2(canal_2)
            led.value(1)
                #print("######################################################################")
                #print("note : ",firstnote+o[n])
                if (n < 12):
                        my_midi.send_note_on(midi.CHANNEL[canal_1], firstnote+o[n]-12, velocity)
                if (n > 11):
                        my_midi.send_note_on(midi.CHANNEL[canal_2], firstnote+o[n]-12, velocity)
            led.value(0)
            #print("####»»»»####»»»»####»»»»#####»»»»####»»»»####")
            utime.sleep_ms(debounce_gate)
            my_midi.send_note_off(midi.CHANNEL[1], firstnote+o[n]-12)
            my_midi.send_note_off(midi.CHANNEL[2], firstnote+o[n])
            my_midi.send_note_off(midi.CHANNEL[2], firstnote+o[n]+12)
            my_midi.send_note_off(midi.CHANNEL[2], firstnote+o[n]+24)
            my_midi.send_note_off(midi.CHANNEL[2], firstnote+o[n]-12)
Thanks a lot
Just to be clear, midi snoop or whatever can see aftertouch messages on the midi/usb output, but the receiving synth doesn’t respond?
If that’s the case then I think it’s your receiving synth that is at fault and not the code. What synth is it and does it support aftertouch?
Hi yes I know but if I plug another synth, a mini brute for that matter, it does send the aftertouch and the synth responds.
I can’t find an example message of a basic note on / note off with the after touch involved… where to put it .
When nothing is being played the aftertouch should be 0, when you play a note and press harder then the aftertouch message with a value between 0-127 should be sent every time the adc inputs changes that the aftertouch strip is attached too. When you release a key or stop applying pressure the aftertouch should return to 0 and nothing should be sent.
So you have to check the adc input in your loop and and send aftertouch when that input changes regardless of wether a key is pressed or not. In reality it should only change on a keypress with pressure.
I’d separate the two: note on/off when the key changes, aftertouch whenever the ADC pressure changes. Then on key release, force aftertouch back to 0 so the receiving synth doesn’t keep seeing a stuck pressure value.
But the key mechanism should force aftertouch to zero or it’s faulty.
And I didn’t suggest that aftertouch is only triggered during the keypress, what I said was monitor the adc input in the loop and send aftertouch when a change is noted,
Thank you. This was for a gig. I did not manage to make it work Before. I was too anxious i guess but now it’s ok thanks to your advices.
This is implémented on the accordion controller
