i found this project for a Ribbon controler.
Here’s the original link of the vid :https://www.youtube.com/watch?v=DDEq7wIxaC8
Ribbon does not really interest me but the possibility of using it as Quantizer with a CV input much more because the code includes several scales and that seem very simple to built.
Many DIY Quantizers are made with PIC and this one with an Arduino simplifies the thing.
here’s the original schem :
And i have a few questions for its adaptation.
The first one is for the CV in.
The original circuit work between 0 to 5V with the ribbon, if i delete the ribbon controler and replaces it by an attenuator pot and a jack socket,
should I add some resistors (voltage divider) to the ground, so as not to damage something because the incoming CVs go I think beyond 5V ? -
The second is about the code.
If i decide to use only Out 1, Gate 1 , Trigger 1 and In 1, should i delete everything related to Out 2, gate 2 trigger 2 and input 2 in the code
or it doesn’t really matter to leave it like that even if there is nothing connected to these outputs
thank you in advance and here is the code for those interested to see or test …
int quant1 = -1;
int quant2 = -1;
int tmp_midi_note1;
int tmp_midi_note2;
byte holdValue1;
byte holdValue2;
RBD::Timer timer;
RBD::Timer trigger1;
RBD::Timer trigger2;
byte count = 0;
byte hold1[5];
byte hold2[5];
byte countplus = 1;
byte tracker1;
byte tracker2;
//ROUTINES!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
//VVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVV
byte majTable[] = {
0, 2, 4, 5, 7, 9, 11, //scale01 Major
12, 14, 16, 17, 19, 21, 23,
24, 26, 28, 29, 31, 33, 35,
36, 38, 40, 41, 43, 45, 47,
48, 50, 52, 53, 55, 57, 59,
60
int minTable[] = {
0, 2, 3, 5, 7, 8, 10, //scale02 Minor
12, 14, 15, 17, 19, 20, 22,
24, 26, 27, 29, 31, 32, 34,
36, 38, 39, 41, 43, 44, 46,
48, 50, 51, 53, 55, 56, 58,
60
int pentaTable[] = {
0, 2, 3, 5, 7, 10, //scale03 Pentatonic
12, 14, 15, 17, 19, 22,
24, 26, 27, 29, 31, 34,
36, 38, 39, 41, 43, 46,
48, 50, 51, 53, 55, 58,
60
int dorianTable[] = {
0, 2, 3, 5, 7, 9, 10, //scale04 Dorian
12, 14, 15, 17, 19, 21, 22,
24, 26, 27, 29, 31, 33, 34,
36, 38, 39, 41, 43, 45, 46,
48, 50, 51, 53, 55, 57, 58,
60
int maj3rdTable[] = {
0, 4, 7, 11, //scale05Maj7(9)
12, 16, 19, 23,
24, 26, 31, 35,
36, 40, 43, 47,
48, 50, 54, 55, 59,
60
int min3rdTable[] = {
0, 3, 7, 10, //scale06 Minor7(9,11)
14, 15, 19, 22,
24, 26, 27, 31, 34,
36, 39, 41, 46,
48, 50, 51, 55, 58,
60
int whTable[] = {
0, 2, 4, 6, 8, 10, //scale07 (WholeTone)
12, 14, 16, 18, 20, 22,
24, 26, 28, 30, 32, 34,
36, 38, 40, 42, 44, 46,
48, 50, 52, 54, 56, 58,
60
int chromaTable[] = {
0,
1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, //scale08 Chromatic
13, 14, 15, 16, 17, 18, 19, 20, 21, 22, 23, 24,
25, 26, 27, 28, 29, 30, 31, 32, 33, 34, 35, 36,
37, 38, 39, 40, 41, 42, 43, 44, 45, 46, 47, 48,
49, 50, 51, 52, 53, 54, 55, 56, 57, 58, 59, 60,
60
int mapMaj(int input) {
byte value = (input) / 36;
// Serial.print(" ");Serial.print(majTable[value]);Serial.print(" ");
return (majTable[value]);
int mapMin(int input) {
return (minTable[value]);
int mapPenta(int input) {
byte value = (input) / 42;
return (pentaTable[value]);
int mapDorian(int input) {
return (dorianTable[value]);
int mapMaj3rd(int input) {
byte value = (input) / 61;
return (maj3rdTable[value]);
int mapMin3rd(int input) {
byte value = (input) / 59;
return (min3rdTable[value]);
int mapWh(int input) {
return (whTable[value]);
int mapChromatic(int input) {
byte value = (input) / 21;
return (chromaTable[value]);
/* Every pot has a different resistive curve. So wire up the
scale select pot, uncomment the Serial.println line below,
turn the pot, watching the numbers on the serial monitor,
and adjust the numbers below to reflect where you want the
pot to be pointing to when you're selecting the modes.
Oh, also uncomment the Serial.begin(115200); line in the
void setup() section.
byte ScaleSelect(int input) {
//Serial.println(analogRead(A5));
int value;
if (input > 0) value = 0;
if (input > 12) value = 1;
if (input > 174) value = 2;
if (input > 352) value = 3;
if (input > 511) value = 4;
if (input > 664) value = 5;
if (input > 858) value = 6;
if (input > 1016) value = 7;
return (value);
int deJitter(int v, int test) {
if (abs(v - test) > 3) {
return v;
return test;
void setup() {
// Serial.begin(115200);
pinMode(2, OUTPUT); //trigger out for #1
pinMode(3, OUTPUT); //gate out for #1
pinMode(5, OUTPUT); //trigger out for #2
pinMode(6, OUTPUT); //gate out for #1
pinMode(9, OUTPUT); //analog output for CV #1
pinMode(10, OUTPUT); //analog output for CV #2
timer.setTimeout(10);
trigger1.setTimeout(10);
trigger2.setTimeout(10);
void loop() {
if (timer.onRestart()) {
count++;
countplus++;
hold1[count] = tmp_midi_note1;
hold2[count] = tmp_midi_note2;
if (count > 4) count = 0;
if (countplus > 4) countplus = 0;
int tmp_read1 = (deJitter(analogRead(A0), quant1) + 20);
int tmp_read2 = (deJitter(analogRead(A3), quant2) + 20);
byte tmp_scale = ScaleSelect(analogRead(A5));
// Serial.print(" tmp_midi_note1 = ");
// Serial.print(tmp_midi_note1); Serial.print(" tmp_midi_note2 = ");
// Serial.println(tmp_midi_note2);
quant1 = tmp_read1;
quant2 = tmp_read2;
if (tmp_read1 < 40) {
tmp_midi_note1 = hold1[countplus];
for (byte i = 0; i < 4; i++) {
hold1[i] = tmp_midi_note1;
tracker1 = 1; // UNTESTED CODE
digitalWrite(3, LOW); // UNTESTED CODE
else {
digitalWrite(3, HIGH); // UNTESTED CODE
if (tracker1 == 1) { // UNTESTED CODE
trigger1.restart(); // UNTESTED CODE
tracker1 = 0; // UNTESTED CODE
} // UNTESTED CODE
if (trigger1.onActive() ) digitalWrite(2, HIGH); // UNTESTED CODE
if (trigger1.onExpired() ) digitalWrite(2, LOW); // UNTESTED CODE
switch (tmp_scale) {
case 0:
tmp_midi_note1 = mapMaj(tmp_read1);
break;
case 1:
tmp_midi_note1 = mapMin(tmp_read1);
break;
case 2:
tmp_midi_note1 = mapPenta(tmp_read1);
break;
case 3:
tmp_midi_note1 = mapDorian(tmp_read1);
break;
case 4:
tmp_midi_note1 = mapMaj3rd(tmp_read1);
break;
case 5:
tmp_midi_note1 = mapMin3rd(tmp_read1);
break;
case 6:
tmp_midi_note1 = mapWh(tmp_read1);
break;
case 7:
tmp_midi_note1 = mapChromatic(tmp_read1);
default:
break;
if (tmp_read2 < 40) {
tmp_midi_note2 = hold2[countplus];
hold2[i] = tmp_midi_note2;
tracker2 = 1; // UNTESTED CODE
digitalWrite(6, LOW); // UNTESTED CODE
else {
digitalWrite(6, HIGH); // UNTESTED CODE
if (tracker2 == 1) { // UNTESTED CODE
trigger2.restart(); // UNTESTED CODE
tracker2 = 0; // UNTESTED CODE
} // UNTESTED CODE
if (trigger2.onActive() ) digitalWrite(5, HIGH); // UNTESTED CODE
if (trigger2.onExpired() ) digitalWrite(5, LOW); // UNTESTED CODE
case 0:
tmp_midi_note2 = mapMaj(tmp_read2);
break;
case 1:
tmp_midi_note2 = mapMin(tmp_read2);
break;
case 2:
tmp_midi_note2 = mapPenta(tmp_read2);
break;
case 3:
tmp_midi_note2 = mapDorian(tmp_read2);
break;
case 4:
tmp_midi_note2 = mapMaj3rd(tmp_read2);
break;
case 5:
tmp_midi_note2 = mapMin3rd(tmp_read2);
break;
case 6:
tmp_midi_note2 = mapWh(tmp_read2);
break;
case 7:
tmp_midi_note2 = mapChromatic(tmp_read2);
default:
break;
// Serial.print(" this is getting sent to pin 9 -- "); Serial.print((tmp_midi_note1 * 20) + 100);
analogWrite(9, (tmp_midi_note1 * 4) + 200);
analogWrite(10, (tmp_midi_note2 * 4) + 200);
} //THIS ENDS THE VOID LOOP() RIGHT HERE!!!!!!!!!!!!!!!!!!
