In? Or out?
Check voltages on the TL072. Post photos of your build.
In? Or out?
It was one of the inputs. I assumed the were the same, but they are not:
A picture of the build
The two inputs should look the same, and should be a sine wave with a small amplitude and a positive offset — so the yellow trace looks kind of like it should, the magenta trace doesn’t.
If the + and - inputs don’t look alike it could mean:
All these were good!
The error came from the values of the resistor I wrote on the PCB. I inverted R6 and R19 values when doing that… I guess I won the right to submit a form to the dumbass dept.
Thanks for your time! The investigations helped me understand a little better this circuit
