Add some screw to the beatbox, and a banana socket for ground
I made a little external box with switch for open or close each sound conected to the Beatbox with alligator clip, to be manage by my first diy gate sequencer
last step re unboxig all in one box with select rotary switch for more sound select, led power indicator, volume out pot
Add another toy inside with pitch mod, led power indicator, volume pot, an LFO …
here’s with the sequencer who control also another sequencer and some toys.
we can also do some bass line (at the end of vid)
There’s no noise it can make that you can’t already make. Most of these are blob dco. I’m all for a hack if there’s a performance or sound to be had or even a gimmick. But that’s way too pricey to be any fun for me.
mind if I ask what the process is like tempo syncing/sequencing toys? I have some ideas in my head but I’m not sure they’d work, and I’m unsure about the voltage difference between toys and modules, I assume I’d probably have to divide the incoming voltage to the toy?
These are old projects but the simplest idea I found at the time was to use a vactrol on toy switches to trigger notes or pads, it works but the best would be with transistors.
