Hello all.
I finally got around to scanning a book im working on. This is a very rough scan of just the notebook. Im presenting it here for review and use. It contains a lot of theorycrafting of my own, so bear that in mind. A good portion of this is subjective to me, but may still be valuable.
There is a plan to revise and actually make this into a proper document, but in case i never get around to it, i figure at least it wasn’t for nothing and if its usable for others great.
Here is a link:
WHAT IS IN THE BOOK:
This book contains:
- A reference of many chords built off of the modes from Major, Natural Minor, Harmonic Minor, and Melodic Minor in the key of C.
- An explanation of intervals with example tunes to help identify these intervals by ear. Additionally, I pair these up with very general feelings (subjective) that i feel with those intervals in isolation. We cover the names of thee intervals, and their inversions.
- Introduce the concept of “Chord Relationships” (CR). These are comprised of two chord qualities (this book only covers major and minor), and an interval between them. The notation in the book uses a lowecase “m” for minor, and an uppercase “M” for major. Additionally, the intervals are signified with roman numerals, and a major interval uses the same “uppercase” roman numerals used when discussing chords. for example, a major 3rd interval is represented like this “III”. The CR is noted thusly: “M IV+ m” means a major chord, followed by a minor chord, with an augmented 4th (tritone) apart.
- We then cover every single combination of chord qualities and intervals, describing the feeling they give. This has helped me a lot because even if its somewhat subjective, its still a helpful starting point to pick CRs.
- This book describes a methodology that does not require that you think of harmony from a scale or mode perspective FIRST. Meaning, you never have to start by looking at available chords in your scale. You pick a key, then a CR. That CR ends with a chord quality, so then, you just pick another CR that begins with that chord quality and it will still work. You can do very complex things that would normally be modal interchange, borrowed chords, etc but its just the same process.
If there is interest, i can run through a few examples since i do not include them in the book. Bear in mind, all scales included as reference do so from the key of C, and all CRs in the back of the book begin with C as the tonic of the chord. In practice, the tonic of the first chord of any given CR will be the same as what you left off from, or if you are just beginning, whatever you want.
