Beatstep pro + 1222 VCO via CV
I just got a beat step pro and I know you can output through midi to the 1222 but I was having trouble controlling it via the BSP CV output, it seemed like the range from an octave on the BSP translated to one note on the 1222.
I haven’t tuned the 1222 in a while, could that be an issue? I only have it plugged into the CV, no other inputs plugged in
I don’t really understand the exact problem, but I would be very surprised if a once-calibrated vco went wrong on its own at this point.
(a small adjustment with the rise in temperature may sometimes be necessary)
was it properly calibrated?
now with the BSP you can easily adjust the VCO.
uses a sequence with 3 differents octaves on the BSP to calibrate the vco with the different trimmers.
Can you share what config you have for the arturia midi control center? There are many ways it can be configured for CV. It may not be configured for v/oct.
Use the 1v/oct input on the 1222 and NOT the CV input perhaps?
