ATTiny85 Noise Generator
This is a small noise gen circuit I found right around when I started getting into noise in general and HNW in particular.
It gives a fairly good noise in full CCW setting on the pot, and a more digital sounding slightly throaty sound in CW.
I used to have a build of it in a plastic project box hooked straight into a Boss MetalZone, and then into a EQ pedal.
The code:
TinyNoise
//  for noise generation
unsigned long int reg;
//  pin setup
const int buzzerPin = 0;
const int buttonPin = 1;
const int potPin = 3;
//  button controls
boolean noiseOn = false;
boolean stillPushed = false;
long lastUpdateTime = 0;
const long debounce = 200;
void setup() {
  pinMode(buzzerPin, OUTPUT);
  pinMode(buttonPin, INPUT);
  // Arbitrary inital value; must not be zero
  reg = 0x55aa55aaL; //The seed for the bitstream. It can be anything except 0.
void loop() {
  //  check for button pushed (on/off control)
  boolean buttonPushed = (digitalRead(buttonPin) == LOW);
  if (buttonPushed && millis() - lastUpdateTime > debounce) {  //  wait for noise to clear
    noiseOn = !noiseOn;
    lastUpdateTime = millis();
  if (noiseOn) {
    //  check pot value (volume control)
    int potValue = analogRead(potPin);  //  0 to 1023
    int frequency = map(potValue, 0, 1023, 0, 1000);
    generateNoise(frequency);
void generateNoise(int frequency) {
  unsigned long int newr;
  unsigned char lobit;
  unsigned char b31, b29, b25, b24;
  // Extract four chosen bits from the 32-bit register
  b31 = (reg & (1L << 31)) >> 31;
  b29 = (reg & (1L << 29)) >> 29;
  b25 = (reg & (1L << 25)) >> 25;
  b24 = (reg & (1L << 24)) >> 24;
  // EXOR the four bits together
  lobit = b31 ^ b29 ^ b25 ^ b24;
  // Shift and incorporate new bit at bit position 0
  newr = (reg << 1) | lobit;
  // Replace register with new value
  reg = newr;
  // Drive speaker pin from bit 0 of 'reg'
  digitalWrite(buzzerPin, reg & 1);
  // Delay (50) corresponds to 20kHz, but the actual frequency of updates
  // will be lower, due to computation time and loop overhead
  delayMicroseconds(frequency);    // Changing this value changes the frequency.
Does the seed value have any notable effect on the output? Do you think it would be interesting at all to add a button to randomize it?
I think I did try it a few years ago, but I can’t remember. Found this snippet somewhere on the interwebz and it worked like I wanted to more or less right away.
I like the fact that it’s so low in parts and still produce a satisfactory end result. When I build a proper module with a PCB and all I’ll probably put an opamp in there as an output buffer. On the standalone box I wired up a dual pot to the freq knob, so i could go between a red and a blue LED as the sound changed.
