Look at what a friend brought to me so I look at it, because when it heats up the trebles fade away…
Damn, those stacked vactrols need a NSFW tag
I wonder what is it part of?
B.t.w. wouldn’t it be a cool name for a new electro/rock/punk/new-wavy/old/medium-large band: “So many Vactrols” ?
Or should that be "Too many Vactrols! " ?
It’s part of an Mesa/Boogie TriAxis guitar preamp.
That’s a CPU controlled tube preamp with MIDI (what a mix !), from the 80’s or early 90’s.
There are even more vactrols on the daughter board (which is all blurred in the first pic) :
Here the Z80 CPU with RAM, ROM and DART serial port for MIDI :
And the whole thing :
While I didn’t really find something, taking it appart, giving it a good cleaning, looking in every corner seems to have fixed it.
Let’s see how it goes in a few weeks…
I see some 500V caps, and some large coils probably for an SMPS-circuit.
Are the vectrols meant to ensure a good separation between the low voltage control circuit and the high voltage tubes ?
I can only guess it’s the case.
The configuration of the tubes also seems to be configurable by the CPU, some vactrols look like they are used as a routing “grid” for the signal path.
More info here :
http://guiguijones.free.fr/Electronique%20&%20Bouine/electronique/Schema%20Amplis%20Effets%20etc/Amplis/Mesa%20Boogie/triaxis.htm
with a link to the schematics (but they are all over the internet).
Ok so I’ll relate this with a pinch of salt… (English for not sure I believe it myself.)
An ex military ferranti engineer tells me that old vactorol kit can crack and absorb moisture which can condense and vary the response with temperature.
I called BS but now have an idea for a smoke LFO.
Any thoughts?
I have no idea, I discovered the existence of vactrols last years…
But if it’s true (and it can well be) it may be the real cause of the problem.
If in doubt… Swap them out.
If it was so easy
But with the number of them, and the way it is build…
And this thing is worth $2000+ … I pass and let a pro check it out
Years ago I ordered a large amount of memory for a Novell server running a Gupta database. The memory cost over £4000. When it arrived I rang the vendor and asked if an engineer would be coming to install this expensive chip. Their response, which has stuck with me all these years was “Go on! Be a Man!”
If it was mine, I would probably try to do it (probably… )
But it’s not mine…
