# SMD resistor series & which can I sub for ERJ-xE?
**URL:** <https://lookmumnocomputer.discourse.group/t/smd-resistor-series-which-can-i-sub-for-erj-xe/1241>\
**Created:** [June 17, 2020, 6:05am UTC](https://lookmumnocomputer.discourse.group/t/smd-resistor-series-which-can-i-sub-for-erj-xe/1241 "2020-06-17T06:05:01Z")\
**Showing post:** 2
**Post date:** [June 17, 2020, 11:00am UTC](https://lookmumnocomputer.discourse.group/t/smd-resistor-series-which-can-i-sub-for-erj-xe/1241/2 "2020-06-17T11:00:33Z")
I think fredrik’s [reply](https://lookmumnocomputer.discourse.group/t/can-i-substitute-this-resistor-with-one-that-has-a-different-series-code/659/2) to your similar question in April answers this one too.
Also, I look on Mouser for 33 ohms, ERJ-xE, and I find 3 entries of which two are in stock: [https://www.mouser.com/ProductDetail/Panasonic/ERJ-6ENF33R0V?qs=50QC8w71jAtDItwiTe6iYQ%3D%3D](https://www.mouser.com/ProductDetail/Panasonic/ERJ-6ENF33R0V?qs=50QC8w71jAtDItwiTe6iYQ%3D%3D) and [https://www.mouser.com/ProductDetail/Panasonic/ERJ-8ENF33R0V?qs=8%2BG0TiN%2FgVpb1yH%2F8k6uQg%3D%3D](https://www.mouser.com/ProductDetail/Panasonic/ERJ-8ENF33R0V?qs=8%252BG0TiN%2FgVpb1yH%2F8k6uQg%3D%3D) (0805 and 1206). Did you need 0603? That one is out of stock. So see fredrik’s answer.
Note on Mouser you can click the check box next to a listing for two or more parts and then hit the compare button to get a side by side listing of specifications.
 ![image](https://global.discourse-cdn.com/free1/uploads/lookmumnocomputer/original/2X/1/1c42d867d55f3ea87d54fa64dafbdc8136ae34da.png)
ERJ-3R is rated for 50V vs 75V and lower temperature range, both of which presumably don’t matter, and is 0.5% tolerance vs. 1%, so is better in that regard.
_[View the full topic](https://lookmumnocomputer.discourse.group/t/smd-resistor-series-which-can-i-sub-for-erj-xe/1241)._
