# Simple distortion unit
**URL:** <https://lookmumnocomputer.discourse.group/t/simple-distortion-unit/639>\
**Created:** [April 15, 2020, 8:41am UTC](https://lookmumnocomputer.discourse.group/t/simple-distortion-unit/639 "2020-04-15T08:41:11Z")\
**Showing post:** 23
**Post date:** [April 18, 2020, 12:47am UTC](https://lookmumnocomputer.discourse.group/t/simple-distortion-unit/639/23 "2020-04-18T00:47:08Z")
While you were preparing that 😃, I entertained myself by calculating the “effective resistance” of a generic small-signal diode, as a function of the voltage across the diode. I-V plots are common, but I couldn’t find a corresponding R=V/I plot so made one myself by stepping through a simulation:
 ![image](https://global.discourse-cdn.com/free1/uploads/lookmumnocomputer/original/2X/f/fa3cc85ebcf7c1d1e67643fbef9ddc53d2ae81f7.png)
The red line is the cut-off frequency for the equivalent 10μF highpass filter (the properties of which keeps changing during the cycle, obviously).
Zooming in:
 ![image](https://global.discourse-cdn.com/free1/uploads/lookmumnocomputer/original/2X/c/c0944d0d637835d3e26108cdd516a6ed2e800e80.png)
EDIT: Turns out the default diode I used has a relatively high reverse current and a lower forward voltage than your typical small signal diode (e.g. 1N914/1N4148) so should probably redo this some day to fix the reverse slope and knee voltage, but the general idea still applies.
_[View the full topic](https://lookmumnocomputer.discourse.group/t/simple-distortion-unit/639)._
