# MS-20 filter stripboard troubleshooting
**URL:** <https://lookmumnocomputer.discourse.group/t/ms-20-filter-stripboard-troubleshooting/3509>\
**Created:** [May 15, 2021, 2:59pm UTC](https://lookmumnocomputer.discourse.group/t/ms-20-filter-stripboard-troubleshooting/3509 "2021-05-15T14:59:44Z")\
**Showing post:** 26
**Post date:** [June 22, 2022, 2:21am UTC](https://lookmumnocomputer.discourse.group/t/ms-20-filter-stripboard-troubleshooting/3509/26 "2022-06-22T02:21:25Z")
The black wire on the pots should be connected to ground. See the note near the bottom. Also the other terminal on the input jack should connect to ground.
See:
> [@General advice for troubleshooting a module and asking for help](https://lookmumnocomputer.discourse.group/t/general-advice-for-troubleshooting-a-module-and-asking-for-help/2049):
> (This is a wiki post, please add and correct!) Look and see if others have had the same problem. Use the Discourse search facility to find topics where the module you’re building is discussed. Inspect your work. Verify all components are correct values. Look for solder connections that are rough, irregular, skimpy, dull, or missed completely (we all do that!) and reflow them. Look for solder bridges between pads and remove them. Check your power connection. If it’s a Eurorack style power cabl…
_[View the full topic](https://lookmumnocomputer.discourse.group/t/ms-20-filter-stripboard-troubleshooting/3509)._
