Are pins 13 and 14 of U5 joined together?
You mean bridged with soldering?
I mean they should be joined on the PCB, 13 and 14 are joined to form a voltage follower, if they are not connected then I don’t know what the results will be, just meter the pins on the chip when its in the socket and see if they are shorted together 0 ohms.
Yes, they are indeed , 0 ohms on the multimeter
Then I’m at a bit of a loss, next thing up the chain is the PIC chip itself. I guess unless you have a scope then looking at the PWM output is not easy.
Hi Craigyb, you were right!!! one of my LM324N is defective, new chips arrive monday…
Have a good day
Thanks for your help
Mike
Glad to hear it, I couldn’t really get my head around the fault other than being the lm324 or possibly the level converter. I built a similar design as a test shortly afterwards with 28 channels and it works perfectly with 4504 and lm324.
I really appreciate all the help
Have a great day Craigyb ( Greg is my brother )
See you
Mike
the level converter is the 4504? Right?
Correct, converts 5v to 10.6v that allows headroom for 0-10v PWM to send to the RC filter and then to the follower input of the lm324.
Ok thanks! I’ll wait for the new chips and I’ll come back with the results…
Kind regards
Mike
WOW! 28? that is quite a big number of channels indeed!!!
Well it is 8 channel polyphonic, so that’s 8 pitch CV and 8 velocity CV channels, plus 4 dedicated to pitch bend, modulation, aftertouch and breath control. Then there are 8 gate outputs, the polyphony can be reduced and if you do that each note frees up two outputs and a gate output to be used for other CV controls and drum triggers etc. it’s still in development, but I’m happy so far.
Well, I just love what I just heard so far. Quite an impressive beast. Keep on the good work:wink:
