# Manual and Dial Phone Gate/Trigger
**URL:** <https://lookmumnocomputer.discourse.group/t/manual-and-dial-phone-gate-trigger/1961>\
**Created:** [October 7, 2020, 1:55pm UTC](https://lookmumnocomputer.discourse.group/t/manual-and-dial-phone-gate-trigger/1961 "2020-10-07T13:55:33Z")\
**Showing post:** 9
**Author:** ![Dud](https://yyz2.discourse-cdn.com/free1/user_avatar/lookmumnocomputer.discourse.group/dud/32/610_2.png) [@Dud](https://lookmumnocomputer.discourse.group/u/Dud)\
**Post date:** [October 8, 2020, 12:40pm UTC](https://lookmumnocomputer.discourse.group/t/manual-and-dial-phone-gate-trigger/1961/9 "2020-10-08T12:40:04Z")
I rather imagined an inverting Gate/Trigger pulse signal, so i think it’s an “inverted positive pulse (0V when switched pushed else 5V)”
for the ~7V i take it in this topic
> [@Need Help: Manual Trigger, 0-5v Out](https://lookmumnocomputer.discourse.group/t/need-help-manual-trigger-0-5v-out/360/9):
> What do you plan to connect it to? If it’s a high impedance (i.e. buffered) input, you can just use a simple voltage divider, like Bitnik suggested [above](https://lookmumnocomputer.discourse.group/t/need-help-manual-trigger-0-5v-out/360/2). If you have a +5 V supply, you can just use a pot as a voltage divider directly, with e.g. a 1k on the way out to limit the current in case you plug it in in the wrong place: If you only have +12 V, add a resistor before the pot to shave off 7 volts: EDIT: you may still want to include the…
if this circuit give me 5V and not 7V i think it’s still ok for Trigger/Gate signal .
I think if i use an opamp for an invert out, and i take a TL072, i can maybe add a second output like this
 ![manual dial phone gate - Copie](https://global.discourse-cdn.com/free1/uploads/lookmumnocomputer/original/2X/f/ff2ce3f604e9e306090c95b519d4063aa16a528f.jpeg)
or not ? 😀
thx
_[View the full topic](https://lookmumnocomputer.discourse.group/t/manual-and-dial-phone-gate-trigger/1961)._
