How to prepare a signal for an ADC?
You sure? I’d think you would want a negative bias on the input, to put the output above zero (if using an op amp powered by 3.3 V and 0 V).
You’d want some protection on the op amp input if the gain were high enough, because if the input gets connected to a ±12 V source and the output voltage is limited to 0 V to 3.3 V, the voltage on the - input pin could be driven beyond the (0-1) V to (3.3+1) V absolute maximum range. But if you’re scaling 10 Vpp down to say 2 Vpp then R2/R1 = 0.2 and that should be safe. Pretty sure… but check!
