# Help for big button
**URL:** <https://lookmumnocomputer.discourse.group/t/help-for-big-button/1698>\
**Created:** [August 28, 2020, 2:45pm UTC](https://lookmumnocomputer.discourse.group/t/help-for-big-button/1698 "2020-08-28T14:45:35Z")\
**Showing post:** 36
**Post date:** [May 12, 2021, 6:19am UTC](https://lookmumnocomputer.discourse.group/t/help-for-big-button/1698/36 "2021-05-12T06:19:17Z")
> [@analogoutput](#):
> So the digital pins should be about 5 V when on.
The stripboard layout has the 78L05 connected to VIN, so the internal supply rail would be ~3.8 V for a regular Nano. Which is 10× the reported value…
> [@Design glitches: Arduino Nano supply voltage](https://lookmumnocomputer.discourse.group/t/design-glitches-arduino-nano-supply-voltage/795):
> (thought I’d collect my nano supply notes in one place to make it easier to link to) A common design glitch in circuits that use an Arduino Nano is to connect regulated 5 V to the VIN pin instead of the +5V pin. This results in the Arduino running at a lower internal supply voltage, often 4 V or below, which may be a problem if the design depends on analog inputs or digital output levels. Voltages below 4.5 V are also out of spec for the 16 MHz clock used by the Nano. Details below, but TL;DR …
_[View the full topic](https://lookmumnocomputer.discourse.group/t/help-for-big-button/1698)._
