# Euclidean Rhythm Generator \[Arduino Based\]
**URL:** <https://lookmumnocomputer.discourse.group/t/euclidean-rhythm-generator-arduino-based/470>\
**Created:** [March 29, 2020, 2:22am UTC](https://lookmumnocomputer.discourse.group/t/euclidean-rhythm-generator-arduino-based/470 "2020-03-29T02:22:08Z")\
**Showing post:** 6
**Post date:** [March 29, 2020, 2:58am UTC](https://lookmumnocomputer.discourse.group/t/euclidean-rhythm-generator-arduino-based/470/6 "2020-03-29T02:58:37Z")
Schematics say “5V / can also be 12V”. Recommended range according to the Nano spec is 7-12 V, so +12 V is ok but 5 isn’t.
 ![image](https://global.discourse-cdn.com/free1/uploads/lookmumnocomputer/original/2X/b/ba814034d8e1ac64f489e4275a928c0a19f0b069.png)
(the Nano FAQ says 6-20 V, the ATmega328 can run at 4.5 V but you won’t get 5 V out, and 20 V is absolute max for the regulator, but then it has to burn away a 15 V drop so you risk frying it if you add any non-trivial load.)
EDIT: To clarify, the ATmega328 can run at voltages below 4.5 V but not at 16 MHz according to the specs, which is why this kind of works until it doesn’t 🙃
_[View the full topic](https://lookmumnocomputer.discourse.group/t/euclidean-rhythm-generator-arduino-based/470)._
