# Eddy Bergman Noise Module
**URL:** <https://lookmumnocomputer.discourse.group/t/eddy-bergman-noise-module/7350>\
**Created:** [July 7, 2024, 4:55pm UTC](https://lookmumnocomputer.discourse.group/t/eddy-bergman-noise-module/7350 "2024-07-07T16:55:03Z")\
**Showing post:** 2
**Post date:** [July 7, 2024, 5:21pm UTC](https://lookmumnocomputer.discourse.group/t/eddy-bergman-noise-module/7350/2 "2024-07-07T17:21:04Z")
First, not all transistors produce noise. It’s being used in a mode it’s not designed for and it’s not guaranteed it’ll do the same thing as the next transistor (especially ones from different batches). I would not solder up a noise circuit without first building enough of it on a solderless breadboard to verify the transistor works.
I have breadboarded that circuit and none of the BC547 I had worked, but several 2N3904 did.
If you don’t have a scope, you can try an [audio probe](https://lookmumnocomputer.discourse.group/t/fast-prototyping/1349/164) to trace the signal. At the transistor emitter (or maybe better at the other side of C1) I’d expect the noise to be faint but audible. At the TL074 pin 1 it should be clear and of course at pin 7. If it’s absent in any of those places that’ll narrow down where the problem is. Of course if you have a scope it’ll be easier to check with that.
_[View the full topic](https://lookmumnocomputer.discourse.group/t/eddy-bergman-noise-module/7350)._
