# 2399 triple splashback delay
**URL:** <https://lookmumnocomputer.discourse.group/t/2399-triple-splashback-delay/879>\
**Category:** KOSMO MODULES\
**Created:** [May 14, 2020, 11:24am UTC](https://lookmumnocomputer.discourse.group/t/2399-triple-splashback-delay/879 "2020-05-14T11:24:36Z")\
**Showing post:** 343
**Post date:** [February 28, 2023, 12:52pm UTC](https://lookmumnocomputer.discourse.group/t/2399-triple-splashback-delay/879/343 "2023-02-28T12:52:56Z")
The pin numbering you show is what I normally use _though it is not universal_. As a result, for an attenuator _usually_ I would have 1 at ground and 3 being the signal being attenuated, unless it’s a situation where attenuation makes some aspect of the circuit go “bigger” or “higher”. So without examining the schematic carefully I can’t be sure but RV2 and RV1 look backwards to me.
RV3 isn’t an attenuator, it’s a variable resistor. Again it depends on the circuit but very commonly you want counterclockwise to be 0R and clockwise to be the full resistance, so you either connect pin 3 to pin 2 or leave pin 3 unconnected, as in RV3.
It’s really easy to get a pot symbol backwards in a schematic and (if it’s board mounted) end up with backwards behavior.
(See: [Schematics (understanding and drawing them) - #46 by analogoutput](https://lookmumnocomputer.discourse.group/t/schematics-understanding-and-drawing-them/1011/46) )
_[View the full topic](https://lookmumnocomputer.discourse.group/t/2399-triple-splashback-delay/879)._
