# 1222 Tuner VCO Triangle Waveform Output Volume
**URL:** <https://lookmumnocomputer.discourse.group/t/1222-tuner-vco-triangle-waveform-output-volume/3014>\
**Category:** KOSMO MODULES\
**Created:** [February 23, 2021, 11:40am UTC](https://lookmumnocomputer.discourse.group/t/1222-tuner-vco-triangle-waveform-output-volume/3014 "2021-02-23T11:40:40Z")\
**Showing post:** 4
**Post date:** [February 23, 2021, 1:21pm UTC](https://lookmumnocomputer.discourse.group/t/1222-tuner-vco-triangle-waveform-output-volume/3014/4 "2021-02-23T13:21:21Z")
> [@CTorp](#):
> the triangle and saw are made from the square with parts of the wave removed so it does get noticeably quieter
Actually the 3340 is a triangle core oscillator, so the saw and pulse are made from the triangle. Saw I think by [switching between original triangle and inverted](https://www.muffwiggler.com/forum/viewtopic.php?p=1144128&sid=64de2552e77c3e5afc4bbb1bf6d56499#p1144128), and pulse by using a comparator. Result (from the datasheet):
![image](https://global.discourse-cdn.com/free1/uploads/lookmumnocomputer/original/2X/5/5531075c360404a6c9cfe35d2aa4291039e3fde6.png)
(Not sure why the saw amplitude is double the triangle, the linked tri to saw method gets you the same amplitude.)
_[View the full topic](https://lookmumnocomputer.discourse.group/t/1222-tuner-vco-triangle-waveform-output-volume/3014)._
